Why is my car leaning?? HELP!!!!
Old Nov 17, 2004 | 10:01 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
I have an 82 Trans Am that I have having a difficult time with. Since I got the car, it has had a problem leaning to one side (passenger side). I have replaced all 4 springs, struts, shocks, ball joints, and control arm bushings. The car still has a noticeable lean to the passenger side...about 1-1/2" lower. It almost seems like sometimes its not as bad as other times. All the tires are inflate to the same psi too. After all ive replaced it isnt any better. I know for a fact the car has never been in an accident either. Have any of you out there encountered a problem like this? I need to fix this because I dont want to have the car aligned with it sitting incorrectly. THX
Old Nov 17, 2004 | 11:18 PM
84L69TA's Avatar
Car: 4 Mopars total
Nobody knows??
Old Nov 17, 2004 | 11:47 PM
Silver_IROC_87's Avatar
hey, im having the same exact problem with my camaro...seems youve covered pretty much the whole suspension. so the less obvious cause is the sway bar......if its bent it can cause the car to lean noticably......my suggestion is disconnect the sway bar and roll the car back and forthto settle the suspension and look again.....thats probly what it is......hope this helps
Old Nov 17, 2004 | 11:52 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
That is a great suggestion.
As long as everything has been checked in the spring can areas (No cracks, rust, or noticibly bend metal) then it is just a case of possible chassis fatigue. After checking that the swaybars are not the cause, you can use coil sporing shims to set the height even without upping that sides spring rate. They have to be shimmed front and rear on that side of the car evenly as not to alter wheel crossweights
Old Nov 18, 2004 | 09:45 PM
84L69TA's Avatar
Car: 4 Mopars total
Thanks guys, but where do I find these spring shims?
Old Nov 18, 2004 | 11:02 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
THese are designed to be fitted to the top of the springs up inside the can. Trim to 42% of the height you need on the frontend.
http://www.secureperformanceorder.co...&ProductID=905
If one front fender is lower 1 1/2" than the other, then cut this shim to aprox .630 or 5/8" tall and insert on top of the coil. The rear I do not have a figure on yet, never measured. It has to be around 50% of the height there also.
Old Nov 19, 2004 | 12:07 AM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
Transmission: slipping 700r4, soon probuilt
so is it like a bent frame or something?
Old Dec 30, 2004 | 04:20 PM
shawnc16's Avatar
Car: 86 IROC, 89 GTA
Engine: 350 blocks, both of em
Transmission: 700r4s
Axle/Gears: 10 bolt and 9 bolt, 3.73, 3.23
Is it just the rear thats sitting lower? I also have the same problem and i was maybe thinking i needed to re adjust my panhard rod. I had mine lowered as well with reloc. brakets and lca's. Try it out you never know
Old Dec 30, 2004 | 05:25 PM
tilstad's Avatar
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
Daym, I hav also had this problem for a while, it's leaning over on the passenger side, sometimes alot, sometimes less.
I did smash it left seideways into a curb ones though, I think it has to be the reason. Nothing seems bnt though. Maybe I'll try to take of the swaybar and reattach, perhaps it would help.
Any other trix to try?
Old Dec 30, 2004 | 05:58 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
have fat cousin albert drive for a while and settle it back out
Old Dec 31, 2004 | 12:27 PM
92camarors5spd's Avatar
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
i know why.....
The chasis is twisted from the torque. Now these cars where never really powerful from the factory. But over time they do twist. Thats why it is strongly suggested that you stiffen up the chasis with various different products. subframe connectors, strut tower brace, etc. Your car will aways have that lean.
Old Dec 31, 2004 | 06:37 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Others have noticed the same thing.
http://www.f-body.com/forum/showthre...tire+clearance
Origanlly posted on f-body.com:
Thomas L. Parker
Weight Bias
If memory serves, this is done because the majority of the time vehicles are occupied by only one person. Adding the driver weight tends to balance the car.
For really serious autocrossers, have the front end aligned with you behind the wheel. I've watched dirt track racers do the same thing with their cars. They put the driver in and then weigh all four corners as a part of the chassis setup.
Tom
Azrael91966669
DIY PROM
25
Jun 20, 2017 04:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
apie2546
Aug 10, 2015 05:43 PM
IROCThe5.7L
DIY PROM
Aug 10, 2015 11:24 AM
