Rear axle question.....
Old Dec 18, 2004 | 06:41 AM
Baylisstic12's Avatar
Car: 1986 Firebird
Engine: 305 V8 Currently being rebuilt
Transmission: 5 spd
To put a fourth gen rear axle on a third gen (firebird) Dies the axle line up with everything or is there a binch of extra stuff I need aswell? Thanx for any info.
Old Dec 18, 2004 | 06:48 AM
ede's Avatar
ede
try this
also typing in word or something similar then doing a spell and grammer check before copy and paste to here would help
Old Dec 18, 2004 | 06:50 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The fourth-gen rear end is a bolt-in. Since the fourth-gen rear end is wider, I doubt (but have no experience) that the axels themselves would swap into a third-gen.
JamesC
Old Dec 18, 2004 | 08:04 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
{Edit} Let me edit this a bit. If you are referring to the "fourth gen rear axle" as the whole rearend, then yes, everything lines up and the rear will swap right in. You may have to work with the e-brake cable attaching points if it's an LS1 rear. The "axles" themselves won't work since the 4th gen rearend overall is wider. The distance from axle flange to diff is longer on the 4th gen rear so the axles won't just swap into a 3rd gen housing. The whole thing will bolt right in but will be wider overall.
Ed
customblackbird
Aug 15, 2021 10:16 PM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
