Odd sound when turning...
Old Dec 22, 2004 | 12:21 PM
IROCET's Avatar
Car: 88 IROC-Z (Sold)
Engine: 5.7L
The other day I noticed a strange sound when I turn the wheel of my car. It started out only when I turned left but is now doing it when I turn left or right. The sound reminds me of rubber squeeling on asphalt. I only notice it a low speeds (under 25), but I can't figure out what it could be. The car drives fine and I don't notice it pulling or steering any different. Any ideas?
Matt
Old Dec 22, 2004 | 01:13 PM
Robg's Avatar
Car: '85 Z28
Sounds like maybe the power steering pump or belt.
Old Dec 22, 2004 | 11:02 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
probally not the case but you said it sounded like rubber squelling on pavement
the front tires always squeeled on my 89 when making sharp turns never knew y but it alwasy did
Old Dec 23, 2004 | 10:05 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Balljoints usually clunk up and down before the squeal. The upper strut mounts will squeal when they begin to fail....
The other suggestions were viable as well. Put it in the air and check out the frt end :-)
later
Jeremy
Old Dec 23, 2004 | 03:47 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
now im not sure about this, so dont quote me, but wouldnt unequal toe result in the tire being "dragged" when turning?
Old Dec 24, 2004 | 08:41 AM
3.8TransAM's Avatar
Depending on how bad the toe is out of whack, yes it would. But usually doesnt make much noise if any unitl the tire is choped or the belt is coming thru and more than likely still wouldnt squael :-)
later
Jeremy
Old Dec 24, 2004 | 11:22 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I'd say powersteering belt, or fluid is low.
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
