Front end rebuild kit?
Old Jan 13, 2005 | 12:20 AM
Avenger007's Avatar
Car: 88 Firebird
Engine: 350 LO5 TBI
Transmission: 700R4 Vette Servo/Shift
Im looking for a good front end rebuild kit. Any suggestions. I like spohns but its $360. Does anyone have performance tierods, idler arm, joints or is it just best to replace them with stock. Im looking for more performance. My 88 has 170k on it so what should i look for in a kit/need? Thanks
Old Jan 13, 2005 | 12:26 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I did mine with parts from NAPA.
Their lower line is Moog, the upper line is even nicer.
I got solid tie rod sleves, through coleman racing, and then ES a-arm bushings. If you really want the best a-arm bushing, the Global-West Del-a-lum bushing are very nice, but come at a price.
https://www.thirdgen.org/techbb2/sho...hreadid=197895
Old Jan 13, 2005 | 04:45 AM
CrazyHawaiian's Avatar
Car: too many ...
IMO there are just some parts of the steering linkage that dont need to be upgraded or replaced unless they are bent or broken. I think alot of these kits are there for people that either got in an accident or people that just want to replace everything for the sake of replacing everything. Thats my opinion of course. I dont want to kill your idea or anything, but I would replace the bushings and ball joints and stuff before replacing an undamaged centerlink. I'm pretty hard on my cars and the stock linkage is good. I would second Dewey's recommendation of stronger tie rod sleeves though. The stock plastic ones are really weak.
Old Jan 13, 2005 | 10:29 AM
Avenger007's Avatar
Car: 88 Firebird
Engine: 350 LO5 TBI
is centerlink/steering linkage the same? Im stuck on old school language from auto manuals, so im rough on this lingo.
i dont have any sort of plan or idea that my mind was set on so dont worry about anyone killing anything i only want to replace parts which actually need replacing or parts that could be replaced for better performance. For example getting a performance centerlink? or is there no such setup?
I believe spohn uses moog parts in their kit. You recommend napa parts though, the "upper line". Thats good because my shop carries those anyways. Ill post a pic of spohn's kit and maybe you could tell me if ill need all that or if i need more.
* Moog Centerlink
* Moog Idler Arm
* Moog Inner Tie Rod Ends (Qty. 2)
* Moog Outter Tie Rod Ends (Qty. 2)
* Moog Lower Ball Joints (Qty. 2)
* Extreme-Duty Tie Rod Adjusters (Qty. 2)
all that is in the kit
Old Jan 17, 2005 | 11:55 PM
Avenger007's Avatar
Car: 88 Firebird
Engine: 350 LO5 TBI
has anyone ever tried the front end rebuild kit found on performancesuspension.com its pretty cheap and looks like a good deal.
Old Jan 21, 2005 | 01:10 AM
redimpss5's Avatar
Car: 85 z28
Engine: 94 lt1
Check with vette brakes. I got mine from them and very happy with what I got and a great price too! www.vbandp.com
Old Jan 21, 2005 | 11:11 AM
91Z28-350's Avatar
The kits replace all the wearable parts on the front end. You don't need to do it all the time, but if it's a first time replacing any of the front end on a 3rd gen, it's a good bet that they are worn out. After that, you can replace the parts as needed. Sometimes it's just easier to replace it all and get an alignment once instead of repeatedly. Alignments cost $$$ and usually aren't done again for free if a part is replaced.
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
italiano67
Dec 11, 2016 09:21 AM
bellez77
Sep 5, 2015 08:39 PM
