Im New and have 1 question
Old Jan 14, 2005 | 01:17 PM
unome81's Avatar
Hi there every one. im new to this site, and recently bought an 88 iroc camaro with a 350 tpi, with goal of 550 hp and to have it be a g machine. now ive been doing a lot of research already, but i want to know what you all think of spohn performance. i have looked over their website, and as far as i can tell, they have all the suspension and chassis stuff i need. i have just never heard of them and was wondering the feed back that you guys that have used their product have.
thanks
newbie
Old Jan 14, 2005 | 01:25 PM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
I cant' believe the 'Search' ****'s havent caught up to you yet.
Spohn? They rock. 'Nuff said.
Seriously, though, they have the best suspension products, and the best rep of any Thirdgen vendor, anywhere.
Old Jan 14, 2005 | 01:26 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
All I have to say is they are the best!! With awesome customer service!!!!:hail:
Kevin
Old Jan 14, 2005 | 01:27 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
https://www.thirdgen.org/techbb2/sho...hreadid=271588
https://www.thirdgen.org/techbb2/sho...ighlight=spohn
i havent heard anything bad about them. i have used them and am going to use them again.
Old Jan 14, 2005 | 01:33 PM
unome81's Avatar
thanks all. that is what i was hoping to hear. oh and one more question before i forget. what is the best springs to get that will lowering a 1-2 inches, and drastically improve cornering?
Old Jan 14, 2005 | 03:34 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
ebiach (sp?) seems to be the fav over the shelf spring setup. Then you will be getting into custom for your setup/style.
Spohn, so far all I have is their subframes, nice. I just got shipping notice of my torque arm :lala: Should be here wed.
Also check out unbalanced engineering, nice products too. More 4th-gen stuff, but some of it is the same.
Old Jan 14, 2005 | 08:56 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
I agree but would add that for handling get the Eibach Prokit rather than the Sportlines. It will be a nice improvement and even better with a good set of shocks. Anything more than that will require that you understand a lot about custom set ups in relation to your driving style etc. - so just get a Prokit and have fun.
Old Jan 14, 2005 | 11:40 PM
VILeninDM's Avatar
George, can you elaborate on this a little? "I agree but would add that for handling get the Eibach Prokit rather than the Sportlines"
I was actually looking at sportlines
Old Jan 15, 2005 | 03:17 AM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
https://www.thirdgen.org/techbb2/sho...hreadid=273133
You need some rake in the car. If you look at the cars with Sportlines the *** end sits too low and they tend to be a bit tail happy.
It's sort of general knowledge as well - like Crazy Hawiian says - he likes the look of the sportlines but prefers the feel of the prokit. Search around a bit, there's lots of posts.
There's a post listing the rates for aftermarket and stock springs. The prokit is around 715 linear front. The sportlines are a bit lower and the other after market springs are really low which = crap in my opinion.
I'm not an engineer but I run my car on long fast road courses and I talk to a lot of engineers at the track; their opinion is that you need some rake in the car; same with Global West, their spring kits have a lot of rake in them.
I think the Prokit is a really good off the shelf set of springs but I also think that I need closer to 800 lbs on the front as there is an uphill right hander on my local track which is like hitting a wall a 90 mph. Apart from that though, the car sits really tight on fast sweepers where I'm afraid to look at the tach/speedo but would estimate something around 80-90 mph.
For street/track I'm finding the Prokit to be a generally good package with Koni Yellows - you can probably do better but for off the shelf it's OK.
Old Jan 15, 2005 | 01:22 PM
VILeninDM's Avatar
"*** sits too low" (I didn't even know you could say '***' )
I thought they drop 1.6" F and 1.3" R.
I have one other question, what's a rake? -- couldn't figure out what you said there and you said the same thing in that other post.
Old Jan 15, 2005 | 02:21 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
Rake is the rear end sitting slightly higher.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
