Pro Kit or Sport Line's
Old Jan 2, 2005 | 07:44 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Time for me to choose the drop height on my 87 IROC project. I will be selecting either the Eibach Pro Kit 1" / 1" or the Sport Line 1.6" /1.3" springs. Would like good, bad and ugly advice from those of you who have dropped your cars. Thanks!
Old Jan 3, 2005 | 02:29 PM
Wadebryant's Avatar
Anyone used these products to drop your thirdgen?
Old Jan 3, 2005 | 05:02 PM
Slow88lb9's Avatar
Car: 88 Iroc 91 Z28
Engine: 5.0 LB9
Transmission: WC T5 / 700R4
Axle/Gears: 10 bolt 3.73
Heres mine with sportlines
Old Jan 3, 2005 | 05:58 PM
91NiteRida''s Avatar
Car: 1991 Camaro
i opted with the sportlines...I just finished installing them on my camaro..I'll post some pics asap...
Old Jan 3, 2005 | 06:05 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Here's mine with a Prokit. It has more rake than the Sportlines and I think the spring rates are higher as well (715 linear fronts). There's a million post about this subject. Thunder Racing has a lowering kit with Adj. Panhard, Relo Brackets and Sportlines. I've had no problems from lowering the car and the Prokit is generally thought to be a better choice if handling is a priority.
Old Jan 3, 2005 | 06:39 PM
CaysE's Avatar
Pro-kits. IMO, if you want to go any lower on a daily driver, you should consider air suspension despite the cost.
Old Jan 3, 2005 | 06:48 PM
tomclf's Avatar
Car: 1987 trans am GTA - sold
I just talked to Steve Spohn about this subject the other day because Spohn performance is coming out with a coil over package for front and rears for our cars. From what he said, this should be ready in the next few weeks. They are more money than the Eibachs but are lighter in wieght and from the testing they have done the handling is going to be much improved. The coilovers will give a 2" adjustment higher or lower from stock.
I have the eibach prokits and wish I had gone for lower - I never have any problems with scraping - ever - but then again my car is not a daily driver. If you like more of a slammed look - go with the the sportlines if the coilovers are not in your budget.[IMG]D/cars[/IMG]
Old Jan 4, 2005 | 04:58 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
I have sportlines on a '91 V6 car- it rides a bit harsh but that was to be expected. The springs actually raised the car slightly from the cut stock coils that were in it when we bought it.
Click on my www link and go to the second page where there are pics of the Camaro.
Old Jan 4, 2005 | 11:32 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
I love my sportlines.... Here are some Pro-kit pics..
https://www.thirdgen.org/techbb2/sho...hreadid=162624
Jason
Old Jan 5, 2005 | 03:09 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Sportlines on my Formula,
Jamex Springs on my Trans Am (Similiar to the Sportlines)
Old Jan 5, 2005 | 10:57 AM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
Now why is George's car lower looking in the front with the prokit than Zephers with the sports?
Im so confused on this subject and have gone back and forth on what i want to get so many times its not funny
Old Jan 5, 2005 | 02:05 PM
Wadebryant's Avatar
Thank you one and all for sending some great feedback and terrific pic's! Thanks!!!
Old Jan 5, 2005 | 04:42 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
pro kit has a nice raked look on my car.
Old Jan 5, 2005 | 06:58 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I love my sportlines. it gives the car the perfect stance and the performance is more than enough to scare you.
Old Jan 5, 2005 | 10:21 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
if your going for appearance reasons...go for the sportlines...
Old Jan 12, 2005 | 11:02 PM
Avenger007's Avatar
Car: 88 Firebird
Engine: 350 LO5 TBI
Transmission: 700R4 Vette Servo/Shift
what about clearance issues though. Im still deciding on either TT2s with 17X11 in the rear or 15X11 both with at least a 295+ tire. Will those work with sportlines?
jeffw what size wheels/tires are those and who makes your wheels? they look like a nice spin off of TT2s
Old Jan 13, 2005 | 04:48 AM
CrazyHawaiian's Avatar
Car: too many ...
I've run both and I prefer the look of the sportlines and the feel of the prokit. Go figgure.
Old Jan 13, 2005 | 04:37 PM
JeffW's Avatar
Engine: 305 tpi LB9
nope not a spin off... boyd coddington.smootie II.. they custom make em for your size wanted with custom offset.
17x8 frt and 17x10 rear
275 47 17 frt
285 40 17 rear
Old Jan 13, 2005 | 04:39 PM
JeffW's Avatar
Engine: 305 tpi LB9
heres a bettr look
Old Jan 13, 2005 | 08:24 PM
blackgold84's Avatar
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
for those of you haveing a 1" lowering spring, can any one or did any one take a free height mesurement of the front lowering spring?
this legth would help me out alot, thanks
Old Jan 13, 2005 | 08:30 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I have some on the floor that are advertised as 1.75 drop, unknown spring rate, are 11.25 free height.
Old Jan 13, 2005 | 08:40 PM
Engine: 350ci
that was fast, thanks
that really helps me out
-doug
Old Jan 13, 2005 | 08:50 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
-doug
Don't rush out and cut them. It depends on the coil count and the wire thickness.
I have very stiff front springs that meause aprox 12" free hieght and yet sits the car about 2" lower than factory.
The springs Dale mentioned sit the same car (lightweight V6's) at about 1/2" lower than stock.
Old Jan 13, 2005 | 09:30 PM
Engine: 350ci
not gonna cut a thing, maybe my knukles, but i think im pretty good
just wanting to get a new front spring set
want the front of the car 1" lower than stock, reasons,
-i think the rake effect looks good
-my stock springs have sagged prolly close to 1"
-better handling, i hope
im gonna get a 5" od linear spring with 650lb spring rate and the free height is all i have left to figure out, was gonna to 13" or so...
any suggestions?
as far a suspension goes on my car, i like the 1le irocs gonna follw that set up sorta, i have the 36 front bar, tds wnder bar, poly endlinks and in the rear i have new moog iroc springs and kyb's, gonna get kyb's up front too, the rear suspension is getting more upgrades because of the straitline performance aplication of my car, this car gets driven every day and doesnt need race car stuff or slammed springs...
cant think of any more
sorry for my lengthy input, but ask far as the original question. the guys here have siad what i think pro kit for perfomance and more of a street driven ride height and sport lines for lower looks and comfortable ride, but these lower the car to much for my tastes any way...
Horridbulldog
Wheels and Tires
Feb 13, 2016 07:22 AM
Ducati900ss
Sep 2, 2015 09:05 AM
gixxer92
Sep 1, 2015 04:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
