Crooked after Eibach install
Old Jan 14, 2005 | 04:16 PM
JerseyMark's Avatar
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
Hey Everyone,
I installed a set of Eibach Pro-Kit springs two weeks ago. I screwed up the indexing of the front drivers side spring. So last weekend, I took it all back apart & fixed the indexing. The car came down about a half-an-inch. But the car was still 1" higher on the drivers side. I loosened the control arm bushings to make sure they weren't binding, but it didnt help. What else can cause the front drivers side to sit higher? I know my alignment is off, so I am going to have that fixed this weekend. But I doubt that my camber being off can cause that corner to sit 1" higher.
Thanks in Advance,
Mark B
Old Jan 14, 2005 | 05:33 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
check the top of the spring, sometimes it gets stuck side ways on the top perch. you will see it if it is not seated all they way in properly. they spring will be bent side ways and hung on the perch happened to me on one side.
jeff
Old Jan 17, 2005 | 07:03 AM
JerseyMark's Avatar
Engine: 96 LT1
Thats it! Thanks Jeff.
Old Jan 17, 2005 | 03:15 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
FYI, when I had my springs out I tie-wrapped the rubber donuts to the top of the spring so they wouldn't move around. That way there was less stuff to fiddle with as I was installing the spring. Glad you found the problem.
Old Jan 17, 2005 | 03:59 PM
JerseyMark's Avatar
Engine: 96 LT1
I used masking tape... Hahaha
NORTz89
May 20, 2020 03:51 PM
deracer
Apr 11, 2016 12:04 AM
Horridbulldog
Wheels and Tires
Feb 13, 2016 07:22 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
