can the new 01 and up m3 and 5 wheels fit
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
will they fit our cars or do they need spacers. what about the 7 series car.
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
bolt pattern wise, yes, but may require a little material to be removed in the lug holes. back spacing wise, what are they?
if they fit why do i have to grind them. i have no clue what the b.s. is its in mm i know that much
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
thier bolt pattern is 120 mm
ours is 4 3/4 or 120.7 mm
thats not much, some people say they need a little removed, some dont, i dont have an experience with them, im just telling what i know
http://www.rsracing.com/tech-wheel.html <good stuff
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would only do it if you are positive you have the wheel centered. Sure they may bolt up, but they may also be that small fraction off front center. At 7mph that will cause a bad vibration and can become dangerous.
Car: '90 RS
Engine: 377 LSX
Originally posted by jocww
so do you guys think i should do it or no
ambainb
Apr 25, 2016 09:21 PM
kah992
Aug 19, 2015 02:55 PM
