Ok to move car without torque arm?
Car: 85 Trans Am
Engine: SBC
Transmission: TH400
Axle/Gears: Moser/Strange 9"
I know to defintely not drive the car without it. But I need to get it off the stands and move it over in the garage. Is that ok to do?
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
[QUOTE]just curious but what would happen if you tried to drive it on the street without it?
the pinion would rotate up, way up. i'm not sure if it would come up enough to unseat the springs, but its not healthy.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Cool so there should be no problem moving the car without a torque arm? I just took my engine and transmission out for a cam and head swap today. And while i'm at it i want to build a decoupling torque arm with sliding upper link while i'm at it.
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
if you drive it, you will tiwist your driveshaft or bust a u joint. buddy tom did it in his 4th gen. he broke a torque arm and didnt know it. driveshaft fell out.
not good at all.
you can push it around or roll it around all day, it wont hurt it.
dont drive it tho....
not good at all.
Car: 82 Z28
Transmission: TH350
Already done, i rolled mine to the end of the drive way without problems. Or course that was without engine or tranny! New torque arm here we come!!!!!!!
AkDrifted
Aug 17, 2015 07:45 PM
