dropped, pinion angle & adj tq arm
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
i dropped my formula over the past few months with a 1.3 drop in the front and 1.6 in the rear. i also used relocation brackets in the drop. iv heard there is ground clearance issues when using a adj tq arm on a dropped car. i thought they were to help correct issues with dropped and modded cars and cground clearance wouldnt be a problem.
can someone make reccomendations for one they use and enlighten me.
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
i installed the Spohn adjustable torque arm/ drive shaft loop kit on my car. the new trans crossmember now sits about 3/4 inch lower to the ground. they also make adjustable torque arms that bolt to the tailshaft where the stock one went. one of these would not affect ground clearance.
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Engine: L98/383
Axle/Gears: 9"
yes they make a few diferent types. i chose the style with the new transmount because with enough power it is possible to snap the tailshaft off. go to www.spohn.net
New2Chevy
Sep 28, 2015 12:35 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
