Profab k-member, Mustang Rack, exhaust issue.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Got my profab k-member in car. Motor in car. Hedman headers and mustang rack. But the hedman shorties don't work with the steering shaft. The #5 primary is just in the way.
You guys who have tubular K-members, and headers, and rack & pinion. What are you using for headers? Got any pix?
-- Joe
-- Joe
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I don't have a R&P but I still had clearence issues with my large tube headers. Nothing a big hammer to the tubes didn't fix. I only had 2 tubes that were causing problems and the worst one was #4 cylinder. The tube is dented so much now to go around the Profab K-member it looks like the k-member pipe goes through part of the header tube.
Many factory headers have strategic dents to clear components. The BBC Hooker swap headers have a dent to clear the steering shaft right from Hooker.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Car: 87 IROC L98
I'd love a R&P but I'm in the same boat. The header tubes with the BBC are just so big that it's impossible to route the steering column through the tubes to where a R&P needs to be hooked up. Even now I had problems running the lower part of the steering column. I had to relocate it on the firewall outward and upward about an inch just to clear the header tubes.
The lower part of the steering column doesn't have to be a single shaft. I've seen custom fabrications to get around obsticles but using 2 short shafts with an extra u-joint and a support. I'm not sure if you have enough room for that but you probably do. It's not cheap though. Good steering shaft u-joint couplers are around $50 each plus the shaft, support etc.
http://www.borgeson.com/products.htm
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Thanks.
If anyone else has. done this with the rack & k-member, PLEASE tell me what headers you have.
-- Joe
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
I had talked to Flaming river about making a custom 2 joint setup...suprisingly the cost was not that bad>>I did not end up doing it...BUT basically they wanted me to spec out how the bracket/support shaft bearing setup wuld look and then give them legnth dimensions... It all sounded very easy to me>>>But I got extremely lucky with my custom turbo headders to where the arm just barely clears... No dents..
I have that exact same profab setup.
the guy I bought it off of had to dent one primary to clear the shaft, that was with long tubes on a small block.
my turbo setup is nothing like that though!
the one thing I don't like about the mustang rack is I have no turning radius at all!
Re: Profab k-member, Mustang Rack, exhaust issue.
-- Joe
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Re: Profab k-member, Mustang Rack, exhaust issue.
Originally posted by Kandied91z
unfortunately i had to have a custom set made... not cheap. they are for sale in the forum for anyone looking with a tubular front end. good luck.
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally posted by SLP IROC-Z
Joe, i need to stop by one of these days to check it out...
Car runs now. Need to adjust valves and stuff, and just mash the rad support a hair more for the intercooler.
-- Joe
Thirdgen89GTA
Sep 12, 2015 08:39 PM
