Should I send my car to a frame shop before i weld in a roll cage
Old Feb 26, 2005 | 12:11 PM
KillerRS's Avatar
Im planning on building and installing a custom 10 point roll cage and my sub frame connectors while i am in school durring the sommer, but i have aquestion. My car has been in a couple accidents on the front end. nothing major, just a couple head on hits and a hit on the front left corner. I dont think that the frame is bent, no crashes happened going remotely fast, but i was wondering if i should send the car to a frame shop before I intall anything that will stiffen the chassis, or should i just measure the front end and if it lines up call it a day. The car is going to be a drag racer, so im thinking the straighter the chassis the better. any suggestions
Old Feb 26, 2005 | 04:27 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
My vote is for the frame shop.
Old Feb 26, 2005 | 11:44 PM
EvilCartman's Avatar
Car: '82 Z28
Frame shop gets another vote.
Old Feb 27, 2005 | 12:59 AM
KillerRS's Avatar
how much does it usually cost? any ideas
Old Feb 27, 2005 | 03:43 AM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
Most places, if not all charge a "hook up fee" to get it on the rack and see if it is out of factory spec, then I belive prolly a per hr. cost for how long it has to be on rig to get it in spec. So you will have to fork over prolly 70 to get it on there to even check it.
But it is a peace of mind thing. With our unibody cars and 3 wrecks even though light ones, There could have been enough to teak it. If your going to do it, do it right
Also,
Another Vote, get it checked
Old Feb 27, 2005 | 11:23 AM
KillerRS's Avatar
Damn straight
Old Mar 3, 2005 | 12:22 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
dont do it half assed make it track straight
Terrell351
Jun 13, 2021 01:13 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kah992
Aug 19, 2015 02:55 PM
z28addict8490
Aug 7, 2015 08:48 PM
