Which rims will fit a 9"?
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
Which rims will fit a 9"? Are they mostly the same 9"?
I'm guessing some Mustang rims will fit? I'm just wondering I should be in the market for...
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
whatever the axles are assuming the rear is the same length as stock, otherwise you will run into backspacing issues. gm rwd bolt pattern is 5 by 4.75. ford is 5 by 4.5 i think
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The majority of aftermarket axles are sold with the GM bolt pattern even if they're for a 9". I special ordered mine with the ford bolt pattern because I use ford drum brakes. Some axles may even have a dual bolt pattern on the flange so you can use them on whatever rims you have.
I use Weld Draglite rims which have both bolt patterns.
Car: Kitt
Engine: Classified
Well, I don't know if it's got GM axles or not. All I know is the GTA rims that came with it, had to be re-drilled in order to fit the rear.
The rear and rims were on an '87 GTA. I'm just wondering which pair of rims I can use for slicks.
Is there a way to tell which axles are in it?
Sorry guys, I jsut realized I posted it in the Suspension section, instead of the Drivetrain, lol. Thanks,
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
Street Lethal
Apr 30, 2019 12:14 PM
Djmathis123
Sep 29, 2015 01:36 AM
