front n rear tire sizes
Old Mar 4, 2005 | 01:32 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
Ok im gettin all new tires but wondering on the sizes. I have stock rims so wats a nice wide tire 4 the rear that i can use? and also wat size should i run in front??
Edit--91' stock rims
Old Mar 4, 2005 | 01:48 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
What size rim..15"...16"?
Old Mar 4, 2005 | 03:23 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
RTFM .... anyways, on the sides of the tires are numbers, typically in the door jamb, driverside near the latch/lock.
Old Mar 5, 2005 | 01:16 AM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
oh 16 inch rim size but i dont want to keep the same size tires as stock, i wanted a wider size tire in the rear.
Old Mar 5, 2005 | 03:34 AM
Avenger007's Avatar
Car: 88 Firebird
Engine: 350 LO5 TBI
Transmission: 700R4 Vette Servo/Shift
remember to keep in mind that you cant rotate, only cross-rotate within same size (not very effective) sure you knew but just thought i would clarify.
If you have 15s go for 235/50 or 60/15s all around
if you have 16s go for 255/50/16s rear and 245/50/16s front.
I believe the stock 15 is 7inch wide
and 16 is 8 inchs. Correct me if im wrong.
Frozer!!!
Jan 19, 2024 04:55 PM
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
MORREALE5
Sep 13, 2015 09:16 PM
