front suspension torq specs
Car: 55 Chevy (the only one that counts), 80 TA, 85 TA, 87 FB
Engine: BBC, BBC, SBC, none
Transmission: M-22, TH400, TH350, none
I am in need of some torq specs. Already did a seached..no luck there. The specs I need are for the complete front suspension:
tie rods, idler arm, pitman-to-centerlink, steering box to frame, a-arms, spindle-to-strut bolts, swaybar bolts (frame), and upper strut bearing plate. The car is a 1985 Trans Am, V8, with WS6 suspension option. Any help would be appreciated. Thanks.
Car: 89 camaro ss
Transmission: TKO600
from chiltons:
spindle to strut 195ft lbs
a-arms 60ft lbs
steering box to frame 70ft lbs
upper strut mount 20 ft lbs
sway bar bracket to frame 39 ft lbs
idler arm to frame 50 ft lbs
tie rods to centerlink 35 ft lbs
tie rods to spindle 35 ft lbs
pitman arm to box 180 ft lbs
sleeves 14 ft lbs
a-arms 60ft lbs
sleeves 14 ft lbs
LT1Formula
Nov 16, 2015 01:13 PM
