How do I get to the top nut on the rear shocks?
Old Mar 15, 2005 | 07:34 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I checked the rear of the car, I dont see any cuts in the carpet, no caps or covers. So whats up here?
Also, I am swapping out the rear springs (already swapped the fronts out). I have the car on jacks under the weld on subframes and the rear end is on a jack. I plan on removing the bottom bolts on the shocks and then lower the rear end down as far as needed. remove the rear springs and installed the new ones. (I'm going for more ground clearance for these crappy Michigan roads.)
And it didnt help that the 6 1/2 quart oil pan stick down an extra 1/2". I had Hotchris (sp) lower springs on it.
Any comments or tips are welcome. TIA.
Old Mar 15, 2005 | 07:41 PM
Steve86TA's Avatar
Car: To many to list
Fold the rear seats down.Pull up the carpet.You will see a small piece of foam,the nuts are under it.
Old Mar 15, 2005 | 10:42 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Actually on mine and i assume all its pull up the carpet?
Old Mar 17, 2005 | 02:51 PM
camaro05's Avatar
Car: 91 Z28
Transmission: built 700R4
what?
Old Mar 17, 2005 | 03:08 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
ME Leigh's been drinking again.
Old Mar 17, 2005 | 03:58 PM
Half-FastRacing's Avatar
Car: 89 IROC-Z
Engine: L98 - Stock
Old Mar 17, 2005 | 08:17 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Look here:
http://pg.photos.yahoo.com/ph/tarami...er72/my_photos
Ed
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
LT1Formula
Nov 16, 2015 01:13 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
