Which front tires/size for 17x9 rim?
Old Dec 29, 2004 | 01:35 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Well, I traded for a set of 17x9" 10-spokes off an SS and some tires. I have a set of Nitto NT555RII's in 275/40R17 for the rears, but I'm going to need some new front tires. For highly spirited street driving, what size/brand tire should I grab? I don't need any all-season stuff...just summer. I bought a set of winter tires for a reason.
To give an idea of the car..
The car currently has WS6 36/24mm bars, KYB GR-2s and Gas-A-Justs, swaybar endlinks, and a TDS Wonderbar. By next summer, it will have new springs (Pro-Kit or something similar...don't want a big drop), poly swaybar bushings, LCAs, SFCs.
I'm thinking something like a 255/40R17, maybe? And then what brand/model tire? I'd like to keep the tires at ~$150 each. The cheaper the better obviously. On www.discounttiredirect.com I can get some Nitto NT555's for $130 each. Would these be one of the better choices? I want a stiff sidewall and something that grips very well.
Old Jan 1, 2005 | 12:40 AM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
try 255/40/17's They look like this:
http://www.fl-thirdgen.org/blacksheep1-featyear.html
This is exactly what your car will look like including the Nittos.
Old Jan 3, 2005 | 12:29 AM
Car: 1997 Corvette
That is the perfect stance I want for my car...what springs are you running?
Tires...555's up front and 555RII's in back? Do you run these when you autocross too?
Oh and by the way, NICE car. It looks great. I'll probably be PMing you sometime soon for some more info on the paint job. I'm planning on painting mine black myself as well.
Old Jan 3, 2005 | 09:54 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I run 275 40 17s all around no rubbing.... if you get your back space right..
Old Jan 3, 2005 | 11:12 PM
Car: 83 Z28
I swapped in an entire Koni suspension from an 84. Shocks/struts/swaybars. I did use the Z28 rear springs though, the Konis actually made the rear end stand up. I cut 1 coil off of the stockers. It has home-made SFC's and a homebuilt panhard bar with heim joints. The trailing arms are Spohn.
These are with the old Goodyears 275 all the way around.
http://www.fl-thirdgen.org/blacksheep-1/camaro.mov
to be honest I'll have to go out and look, I think they're 555's
I lost track of this post, that's why it took so long to get back, sorry.
Old Mar 17, 2005 | 08:16 PM
esc's Avatar
esc
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
So what back spcing do you recommend?
I have 17x9 with 5" BS all the way around and want to run 275-40-17's.
Old Mar 17, 2005 | 08:30 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
https://www.thirdgen.org/techbb2/sho...hreadid=279397
Kat
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
Exxon Limited
Aug 9, 2015 08:13 PM
