Bolt size for strut tower brace install
Old Mar 27, 2005 | 12:32 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
How long of bolts should I use to install my Jamex STB? They appear to be 5/16" or 3/8" width holes (haven't measured yet), but what length should I use in order to clear everything?
Old Mar 27, 2005 | 04:44 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
The bolts that attach my Hotchkiss STB bracket to the strut towers are 5/16" by 1" long. The guage thickness of my bracket is about 4mm.
Old Mar 27, 2005 | 07:12 PM
Car: 1997 Corvette
Cool thanks a lot, that's what I'll be buying tomorrow
Probably a good idea to use washers on the underside of the strut tower right?
Old Mar 27, 2005 | 08:54 PM
Jade Grey's Avatar
Engine: 305TPI
Yeah, use a washer on both sides, bolt head and nut.
A Hotchkiss uses a wide fender washer on top and a very small diameter (in comparison with the bolt head diameter) zinc-plated washer on the underside. It's not an USS or SAE washer so I guess it's a AN or something.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
knight72
Aug 10, 2015 09:32 PM
