Front wheel fitment issue!! its quite the stumper!!
Old Apr 7, 2005 | 12:22 AM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
All I want to do is put my 17" Zr1s on my 92 camaro rs. I have put a tubular k-member and tubular a-arms on because I thought the stock member might have been bent but the 17s still hit the front corner of the ground effects and rear wheel well. I tried to change the alignment all around to get them to fit and had no luck. I cant even get this set of Irocs I have to fit with 235-50-16s. The 17s have 245-45-17s on them. I cant figure it out why wont the wheels that were designed to fit, work on the car. I have 17 zr1s with 38mm offset and 2" spacers just as skulte specifies and I cant get em to fit but they are pretty close.
Old Apr 7, 2005 | 02:22 AM
Kandied91z's Avatar
sounds like something else is bent..
Old Apr 7, 2005 | 09:28 AM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
can't really tell much without seeing some pics.
Old Apr 7, 2005 | 01:10 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Is it on one side or both? Did you try and change caster? Less caster should move the tire forward.
Frozer!!!
Jan 19, 2024 04:55 PM
B_Dubya
Aug 26, 2015 05:09 PM
kah992
Aug 19, 2015 02:55 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
wruiz
Aug 11, 2015 02:59 PM
