Rear Sway bar brackets
Old Apr 6, 2005 | 04:23 PM
phishfud's Avatar
Car: 88 GTA
I pulled my rear end out, and the brackets that hold the sway bar to the axle didn't make it. These are the ones that look like an exhaust clamp. Anyone know where I can get new ones? I looked everywhere and cannot find the part number, and have only seen these listed in new sway bar kits. I have a factory 24mm rear bar, and wasn't going to chnage it. Any info here would be great. Thanks.
Terry
Old Apr 6, 2005 | 04:31 PM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44 IRS, Tru Trac, 3:73 gears
sway bar brackets
Let me take a look, I think I have a set of those in a box of parts I'm not going to use. I'll get back to you soon.
Old Apr 6, 2005 | 07:30 PM
phishfud's Avatar
Car: 88 GTA
That would be fantastic. Just keep me posted. Thanks alot.
Terry
Old Apr 6, 2005 | 07:40 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
Re: Rear Sway bar brackets
If your still in need of the brackets don't forget about Spohn.
http://www.spohn.net/product.cfm?productid=1360
Old Apr 6, 2005 | 07:51 PM
phishfud's Avatar
Car: 88 GTA
I did see those, but that doesn't include the brackets or clamps you might call them that would hold the bushings to the axle. They kinda look like an exhaust pipe clamp. Those are what I cannot find. Thanks though.
Terry
Old Apr 6, 2005 | 07:55 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I bought mine from the local dealership. $7 apeice though.
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
ahh, sorry for the mixup . . .
What you are looking for is the U-shape bolts and nuts that attach to those brackets.
Old Apr 6, 2005 | 07:59 PM
phishfud's Avatar
Car: 88 GTA
Exactly! I should have mentioned U shaped. Anyone have a source or part number? Thanks alot.
Terry
Old Apr 6, 2005 | 08:01 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
try this P/N 10018208
GMpartsdirect.com lists them for 3.33 /ea.
Old Apr 6, 2005 | 08:06 PM
phishfud's Avatar
Car: 88 GTA
I looked it up on Gm Parts Direct, and it listed that number as a bolt. Maybe I'll call the dealer with that number tomorrow and see what they can tell me. Thanks.
Terry
Old Apr 6, 2005 | 08:08 PM
phishfud's Avatar
Car: 88 GTA
I just did a little further digging, and that is the U bolt, but is listed for a 93 and up. This is what I need, as the bottom part of the assembly is fine. Think it will work on my 9 bolt? Didn't know if Gm changed the diameter of the rear ends in the 4th gens.
Terry
Old Apr 7, 2005 | 02:30 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
10018208 as posted by adambros is the correct #.
Old Apr 7, 2005 | 03:41 PM
phishfud's Avatar
Car: 88 GTA
Great. Thanks for the input guys. I'll order up a set then. Take Care.
Terry
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
z28addict8490
Aug 7, 2015 08:48 PM
