18" wheel will these fit??
What we have is a 1989 TA. We are looking at 18" wheels here are the specs. 18x9 5 on 4.75 +14mm offset with a 5 1/2 bs Anyone running this size?? What size tire looks best on the 18" wheel. I did search the site but with all the diffrent combos out there it got me more
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
well i dont know about offest , our cars have no offset from what ive found . But all i know is i have 18x8 on the front with 4.5 backspacing and the rears are 18x9.5 with 5.5 and its great .
depends on what size tire your trying to match. a factory 91 z28 uses a 245/50/r16 on a facotyr 8" rim. so to match the tire height and dimensions you'd want a 275/35/18 which would be the best tire.
try using a calculator to help you.
http://www.miata.net/garage/tirecalc.html
you'll need adapters. go here.
www.skulte.com
the popular offset for our cars is a 0 mm front and a +16mm rear. this is of course a 10 bolt 4 wheel disc optioned vehicle. those with the 9" rear or drum brakes have a different rear offset.
www.skulte.com
ambainb
Apr 25, 2016 09:21 PM
kah992
Aug 19, 2015 02:55 PM
