Which front springs should I get? Drag...
Old Apr 20, 2005 | 07:07 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
It seems that summit lists them according to #/in. Anywhere from 212 lbs/in. to 270lbs/in. Which one would be right? I don't have the front end weight of my car. I do have some weight reduction up front. Such as...
Al. heads,
elec. water pump
fiberglass hood
no AC or smog
headers
no power steering
fuid over flow stuff.
al. intake
battery relocate
yada yada
I have no idea what to get...
Old Apr 20, 2005 | 08:10 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
You could always use stock V6 springs....work great for drag application......I have them on my car....Getting ready to installed handling springs if you are interested?
Old Apr 20, 2005 | 10:06 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
nevermind. Looks like moroso only carries one kind for a 3rdgen.
Thanks for the offer, but I already ordered some from scummit.
Old Apr 20, 2005 | 10:25 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Those should work great.....
Old Apr 24, 2005 | 05:51 PM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
Moroso drag springs need to be cut. It sits like a gasser until you do. They tell you to cut half a coil off at a time.
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
deracer
Apr 11, 2016 12:04 AM
TA8487
Aug 11, 2015 09:02 PM
