Damage bad strut mounts can cause?
Old Apr 25, 2005 | 12:31 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
What could bad strut mounts do? cause any damage or excessive wear on anything?
Old Apr 25, 2005 | 04:21 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
Can cause premature tread wear, cause unwanted front suspension geometry change resulting in poorer handling, and if severely broken could uotright be dangerous becuase it can cause a complete failure in front strut damper if the rubber in the strutmount breaks away entirely and bounce you off the road like a basketball. Also may dent the hood from underneath. I have personally never see one get so bad as to completely fail, but I have see many that are very close and scary.
Old Apr 25, 2005 | 04:29 PM
92MaroRS's Avatar
as of right now all its doing is that it creaks when the wheel is at full lock, either way.
Old Apr 25, 2005 | 04:33 PM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TH-350
I recently rebuilt my front suspension and I replaced the strut mounts. When I took the old ones out I noticed that on both the rubber had split at least half way around the circumference! Glad I replaced them, coulda been ugly. I think this part gets overlooked too often on thirdgens. Although I haven't heard of failures yet either, as these cars get older it is bound to happen.
Frozer!!!
Jan 19, 2024 04:55 PM
NORTz89
May 20, 2020 03:51 PM
Vintageracer
Jan 10, 2020 05:33 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
