rim question
Old May 2, 2005 | 01:51 PM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
rim question
hey all i recently picked up a set of 15x7 draglites and would like to put a set of et streets on them i was wondering since they are 15x7 can i use a 15x8 tire?
also what would be the best size tire?
also the car has 4:10 rear i know it's to much gear for the tpi
so what would you guys go with for the et streets?
thanks
Old May 2, 2005 | 07:48 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
15x 8 tire no such animal. if your asking if you can use the tire off your 15x 8 wheel that should work ok as long as it is not some crazy 50 series tire. if it is a 70 series it will work great if its a 60 series it may be a little tight and wear funky.
jeff
Old May 3, 2005 | 12:00 AM
Bobbyz's Avatar
Engine: 350 "ZZ4"
thanks for the input
actually what im askling is can i put a 15x8 tire (slick) on a 15x7 rim
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Djmathis123
Sep 29, 2015 01:36 AM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
