RPO code for rear end gear ratio
I tried using the RPO decoder but it won't come up for some reason. anyone know the RPO codes for an 85 Camaro (with disk brakes if that would narrow things down). I am trying to find the rear end gear ratio.
You can kinda figgure it out by looking at the tech data page:
https://www.thirdgen.org/newdesign/tech/techdb.shtml
Match up your year and model with your engine code and weather or not you have the G92 RPO and you should be able to find out.
Car: 4
Engine: 6
Transmission: 5
Or, do the right thing, and go straight to the source, such that no confusion or error will be possible.
Take off the cover and look. It's the only way to be sure.
Changed the fluid lately? Then it's long overdue. While you're catching up on the maintenance you've been slacking on, make a point of looking at the gears. The ratio is stamped right on the edge of the ring gear. 41/15 = 2.73; 41/11= 3.73; 42/13 = 3.23; etc.
Car: 84
Engine: molested 350
Transmission: th400
Originally posted by transam84
I know cracking it open is the only real way to find out but I just don't want to open it up right now if I don't have to.
sounds like you need to sell the transam and buy a honda..... its best just to pull the cover and take a peak inside
sell the Trans Am and buy a Honda?? not sure what thats suppose to mean. this rear end I am trying to get the gear ratio for is off of an 85 Camaro parts car and not on my Trans Am, well I guess this thread was useless. moderator if you want to close out this thread go on ahead.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
