WS6 vs. stock Camaro suspension.
Old May 7, 2005 | 01:58 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
What are the differences between the WS6 package on the Trans Ams and the Camaro package? Will the WS6 bolt onto a Camaro of the same year?
Old May 7, 2005 | 03:59 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
WS6 is the top of the line handling package. But it was only available on the pontiacs. All parts are interchangeable.
Old May 8, 2005 | 09:16 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I thought so. What are the differnces? The shocks, struts, etc? Is there a difference in the sway-bars?
Old May 8, 2005 | 09:36 PM
NEEDforSPEED's Avatar
WS6 is the top of the line handling package, and the LE1s are what? 2nd? lol,
i dont think the WS6's got factory wonder bars like the irocs did?
Old May 8, 2005 | 10:39 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Wonder bars do what, exaclty?
I want to improve my susspension to at least WS6 or LE1 quality. What do I need to do this?
Old May 8, 2005 | 11:07 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
You are correct the LE1 is the best, but i didn't include it because it had to be specially ordered and barely any were built during its limited availability.
Old May 8, 2005 | 11:11 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
If I have my knowledge correct wasn't the WS6 package a Pontiac only option? From what I see in car weights the fully loaded Pontiacs were much heavier cars so thus they would require a heavier rate spring to compensate for the wieght of the car to make it handle decent.
Put those WS6 springs on a lighter weight car and they will make it transistion betterwithout as much weight transfer under acceleration, cornering,or braking.
Regardless, any stock suspension- espceially one 20 years old- is nothing to write home about. Upgrade the bushings and shocks with aftermarket options rather than factory new replacements and the car will handle much better in transitions.
Old May 8, 2005 | 11:26 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
le1? Do you guys mean 1LE? That wasn't just suspension by the way, that's things like radio and AC delete as well.
I was under the impression that the maros got the better springs rates? (not like that matters on these old cars anyways, you're better off with newer springs)
Old May 8, 2005 | 11:35 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Duh, i'm retarted!
Old May 9, 2005 | 01:40 AM
83 Crossfire TA's Avatar
1LE camaros got the same basic rates and bars that the WS6 cars did + things like AC and power junk deletes, bigger brakes…
TTA’s and a few others were available in the Pontiac line with the bigger brakes of the 1LE packages.
As cars rolled down the assembly line they had springs installed according to their assembly weight… for example, there were 3 possible front springs a WS6/1LE car could get depending on their weight. Also, FWIW, Pontiacs almost always got 1 step stiffer rear springs then the comparable camaro setup which gave them more neutral handling from the factory on top of already getting stiffer springs since on average they were 130-140lbs heavier.
camaro71633
Sep 1, 2015 10:24 AM
mcgarnicle
Aug 12, 2015 04:58 PM
drathaar907
Aug 10, 2015 07:44 AM
drathaar907
Aug 6, 2015 04:20 PM
