Tire info Re:1988 Firebird GTA Trans Am
Old May 10, 2005 | 11:04 PM
Arnabowl's Avatar
Car: 1988 Firebird GTA Trans Am
I have been told by numerous tire stores that my current tires P245/50R-16 are not rotatable.
Is this true?
And second can anyone tell me the original tire sizes that came with my ride. It has the original aluminum rims.
Thanks, Arne
Old May 10, 2005 | 11:19 PM
90iroc5spd's Avatar
Car: 87 aniv vert, 90 Iroc, 87 LT
Engine: LB9, LB9, carbed 305
Transmission: MM5, MM5 conversion, MM5 conversion
Axle/Gears: 3.45, 3.73, 3.73
the reason they are not rotatable is not the tire size, it is the fact that the front wheels are different than the rear wheels. They have different offsets. the only way to rotate is to break the tires down and move them from the front wheels to the rear and vice versa
Old May 13, 2005 | 02:48 PM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
[QUOTE]Originally posted by 90iroc5spd
the reason they are not rotatable is not the tire size, it is the fact that the front wheels are different than the rear wheels. They have different offsets. the only way to rotate is to break the tires down and move them from the front wheels to the rear and vice versa [/
Yep, and some tire places are A$$es when it comes down to that. Specially if they are directional tires. Like mine Kuhmo 711's.
Old May 15, 2005 | 03:54 AM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
How are tire places asses by telling you a standard rotation can't be done and it requires remounting and balancing all for tires?
Old May 15, 2005 | 08:18 AM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
just wondering if this is the same for the WS6 formula firebird wheels?
i tried looking at them, and they all looked the same. i also had two that were dented, and a donor car 91 Formula 350 had two better ones so i used them
they looked the same, and when i had the tires off, i couldn't see any difference internally
does this only apply to the GTA rims?
i know one thing that will determine whether you can rotate or not is if you get a direction tread.
the BFG's we bought weren't directional, rather an all season
245 50 16
Old May 15, 2005 | 10:17 AM
project_91RS's Avatar
If you look at the wheels they should be stamped front and rear, they have different offsets, that is why they cannot, or shouldn't be, interchanged. IMO, don't bother rotating them.
LilHot
South Central
Apr 13, 2026 11:46 PM
colton_carlson
Mar 8, 2019 12:21 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
gta power
Aug 13, 2015 06:15 AM
