15x28x13.5 Mickey ETs on back??
Old May 16, 2005 | 11:29 AM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
Well I ordered some 15x28x13.5 Mickey Thompson ET Streets off ebay and it turns out they stick out and hit the top of the outside wheel well lip.
But I thought I've heard of people putting 28" tall tires on these cars?
Guys w/28" tall tires, how wide of a tire did you put on? Did you have to do any suspension work to get them to fit? I'd like to get 28" tires again, but is it even possible? These tires that I got were off a 4th gen, not sure if he had any suspension mods. Thanks.
Old May 16, 2005 | 06:24 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
28" tall tires are one thing...but when you try stuffing a 28" tall tire that is 13.5" wide...problems come up. You're going to, at LEAST, need to roll the fender lip and beat the wheel wells to stuff those in there.
Old May 16, 2005 | 10:01 PM
batchik2's Avatar
Car: '86 Z28 Chassi, '91 V8 S10
Engine: 350 bored .030 new cam, #416 heads with 1.94" intakes
Transmission: S10-NV3500 5spd
just go with a 10.5 thats plenty of traction for the power your putting down.
Old May 16, 2005 | 10:25 PM
mdricken's Avatar
Car: 92 Camaro
Thanks for the replies.
Does a 28", 10.5 wide go into the wheel well without any modifications? If so do you guys know what backspacing is needed? Thanks.
Old May 16, 2005 | 11:22 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i run 28x10.50 hoosiers with just a little fenderwell beating. they're on a weld pro star 15x8 with 4.5BS. pics in car domain site in signature.
Old May 17, 2005 | 01:24 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I've run 28x10.5 ET Drags on 15x8 rims with 5.5" BS, they fit fine width-wise (didnt even stick out past the fender) but I had to beat the crap outta the front of my wheel wells.
Old May 17, 2005 | 12:20 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Blackroc86 has 28x13.5x15 ET-Streets on 10" rims with 5.5" backspacing. He said that he took a hammer to the inside and trimmed a couple of bolt ends off.
Pics can be seen here:
https://www.thirdgen.org/techbb2/sho...hreadid=294662
Fronzizzle
Mar 18, 2019 08:29 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
