Question on strut choice.
Old May 20, 2005 | 08:28 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
Im looking to replace my worn struts and i wanted to know what the best ratio would be to get for all around driving/ aggerssive cornering.... i like to go into the twistys hot.
ive seen 70/30 and 90/10
what do these ratios represent??
Old May 20, 2005 | 09:52 PM
CrazyHawaiian's Avatar
Car: too many ...
Those represent compression and rebound. Dampeners for drag racing are usually represented like that. If you want dampeners for the twisties then you want adjustable. Stuff like the Koni's or Tokiko Illuminas. You can change the settings after driving to tune the car better for your style of driving (more oversteer/understeer). Some of the non adjustables will work good too. Ground Control has a nice list of shocks and struts. But you can probably get them cheaper somewhere else (still, good for referance).
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Apr 25, 2017 07:14 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
