Clunk from steering column?
Old Jun 2, 2005 | 12:01 PM
REDRIGHT9's Avatar
Car: 1991 RS
Engine: 305 TBI
Transmission: AUTO
I am hearing a clunk noise from my steering if I turn the wheel back and forth parked..It sounds like its comming from the steering column, The front end parts are tight and when I grab the column (under hood) it has some play in it..It seems to be loose where, I think, the intermediate shaft goes into the column by the firewall..Is this common on these?? is this part hard to find and repair??
Old Jun 2, 2005 | 11:42 PM
Chris Luongo's Avatar
I just started getting the same problem with my car.
If you use the search feature here, type in "rag joint" and you should find all the information you need.
The part you're probably going to end up getting is Motormite (that's the maker of the HELP! brand) #31008. It's a special order part at AutoZone, for $36. There are also rivets on the original part you'll have to drill out.
Old Jun 3, 2005 | 05:08 PM
REDRIGHT9's Avatar
Car: 1991 RS
Engine: 305 TBI
Transmission: AUTO
I thought the "rag joint" was by the steering box end of the column..I am talking about the other end, tward the fire wall...
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
