whats causing my crappy 60'?
Old Jun 4, 2005 | 12:26 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i used to pull 1.9 / 2.0 60' foot but recently my best is only 2.1 60'
my better times were on bald street tires and my new times are on new kumhos but the catch is my torque arm mount has dissapeared. literally.. no bushing left. would that little bit the torque arm moves have caused enough pinion angle change to gimme ****tier launches?
Old Jun 4, 2005 | 03:15 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
... replace the bushing.
Preferably with a poly mount like an ES piece. I'll say though, those aftermarket mounts are a pain in the *** to install. Though I must say I'm curious as to how the bushing disappeared. Those things are riveted to backing plate/mount.
I went from my weak/worn stock piece to an ES piece and I eliminated my wheelhop problems.
Old Jun 4, 2005 | 08:20 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: whats causing my crappy 60'?
Um,, yeah, that would cause it. Without that bushing, your rear end is moving all around, throwing your pinion angle out of wack. Put a Poly in there and enjoy the traction.
Old Jun 4, 2005 | 11:31 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ok thanks just making sure that was my main concern.
i do in fact have the ES mount, but im gonna need help getting the old one out first. long story, but its gonna need either the tranny dropped or cutting some bolts to get it out.
im not sure either how it dissapeared, the rivets are still their to some of the chunkjs of rubber, but the majority of rubber is gone. like a peice fell out and the driveshaft slowly tore the rest away i guess.
Old Jun 5, 2005 | 12:40 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Fix your suspension before complaining about bad 60' times. Eliminate the obvious problems first.
Old Jun 5, 2005 | 01:35 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i know, was just curious and looking if thiers anything else i should check into while im under thier.
HoosierinWA
Oct 7, 2015 10:15 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
mfp189
Sep 27, 2015 09:25 AM
