Ground Control Weight Jacks
Old Aug 15, 2012 | 11:40 PM
  #101
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: Ground Control Weight Jacks
800?? I'm about to say fu** it and just get a couple different poly spacers and see what i like
Old Aug 16, 2012 | 07:22 AM
  #102
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Buy poly spacers & if you don't like it you hafta buy more or take some out but it does nothing for the spring rate.
Buy weight jacks & it won't cost you anything but time to go higher or lower. Depending on how low you want to go, you'll just hafta decide on a spring rate. Or to go to a different rate later it is only $50 for new springs. Compare that to the cost of spacers.
I'll never go back to a static lowering job again. I'd go air bags if I could afford them.
Old Aug 16, 2012 | 11:05 AM
  #103
87350IROC's Avatar
Car: 87' IROC
I would love to have the ability to go down to the bump stops, and raise it one inch from that above hieght
That should be no problem at all. My adjustment range is from bump stops to 26.5"
Old Aug 16, 2012 | 10:36 PM
  #104
89ROC-Z's Avatar
Car: 89 IROC-Z
Thanks for the pic and you have a PM.
IS that at 26.5" fender lip height?
Old Aug 17, 2012 | 12:31 AM
  #105
87350IROC's Avatar
Car: 87' IROC
Right. My front 8" springs range from 24" (on the bump stop) to 26.5". My current ride height is 25.5" and that is pretty close to the max height of the adjuster. Remember 1" on adjustment on the adjuster is well over 1" of ride height change on the front due to the a-arm arc. So the bottom 2" or so of adjustment is on the bump stops. On the rear I can only get down to about 26" with the adjusters bottomed out and the OEM isolator installed. On the rear, 1" of adjuster change equals 1" on ride height change.
This is with 850lb front and 175lb rear springs.
If I had to do it again, I would get 9" front and rear springs to get me closer to the center of adjustment range.
Also, keep in mine the 24" front bump stop height is with Ground Control soft strut shaft mounted bump stops. I have no idea what the ride height would be on the OEM bump stops.
John
eightsixseven
Dec 16, 2024 01:50 PM
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
Horridbulldog
Wheels and Tires
Feb 13, 2016 07:22 AM
Linson
Nov 12, 2015 08:09 PM
