Spohn Crossmember for 3550
Old Jun 7, 2005 | 06:08 PM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
Transmission: Tremec 3550
Ok I got a the spohn crossmember for my 92 rs. Put in my tremec 3550 and now I have some bad vibration/clunking issues. I've checked the usual, mounts, u-joints, 180* swap, etc. I figured the drive shaft was out of alignment because the spohn mount sucked. It didn't line up at all. So i cut off the small hump that was put on the cross member to make push the tremec up a little higher... This helped the vibrations a ton. I can still see the tranny shake in 3rd up but it doesn rattle my center console.
The vibration could be from my pilot bushing so I'm not terribly concerned that it is the cross memeber. But the think is really bad. It happens real bad in 1st and gets a little better in each gear. You can barely notice it in 5th. You can see the shifter slam to the right about a 1/2 inch when you step on the gas and watch it slam back when you let off. It moves the opposite in reverse. So I'm thinking it might be the TA but I'm not sure why it would do it now but not with the t-5. Any ideas?
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
kammi10
Nov 9, 2015 08:28 PM
darwinprice
17
Oct 11, 2015 11:51 PM
tmork454
Sep 29, 2015 06:33 PM
luvofjah
Sep 10, 2015 10:41 AM
