shock install help
Car: 2003 - 2004 chevy avalanche 1995 z28
Engine: 5.7
Transmission: 6 speed
shock install help
im going to change my shocks with bilstiens, ive done shock intalls in the past, but neeed some help with insrtutions on how to intall rear shocks...thanx
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
Pull back the carpet in the hatch area right where the shock it and unbolt it just like you did the front its not that hard you'll be fine.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You can change the rear shocks in less than 10 minutes once the car is in the air and supported on jack stands.
As stated above you need to fold down the rear seats and peel back the carpet to expose the top shock mount.
- Place jack stands under the rear sub frame and let the rear end hang with a jack supporting it under the pumpkin.
- From the back set set your wrench on the nut and put a pair of vise grips on the the top of the shock shaft (to keep it from spinning).
- Once the nut is off you can lower the jack that is supporting the rear pumpkin and the rear will lower. You can then remove the lower shock bolt and take the shock right out.
-Bolt the new shock in to the lower mount.
-Raise the jack to lift the pumpkin and guide the top shock mount through the opening hole.
-Place wrench on nut and attach vise gripes to top of shaft.
-Thighten down.
Thats it. Very easy with simple hand tools.
-Thighten down.
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
Nov 16, 2015 01:13 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
