Spohn SFC install (carpet issue)
Old Jun 19, 2005 | 05:52 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
I just pulled back the carpet in my car, but i did not remove it completely, i rolled it back to the console as tight as i could to get it away from the sides of the car....should i be ok when the mechanic welds the connectors on? did anyone else do what i did with the carpet? did you make out ok (as far as not burning a hole in the carpet)
Old Jun 19, 2005 | 06:33 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
You should be just fine.
Old Jun 20, 2005 | 06:53 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
never pulled the carpet when I had my Spohn SFC's welded in. A good welder using Spohn's instructions for a weld every 6" should not generate enough heat to damage the interior.
Old Jun 20, 2005 | 02:23 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
I dont care how good you are, the small cross brace tubes weld to the floor right in the middle of where your seat is and the carpet is directly on top of that and it WILL get hot enough to burn the carpet.
Old Jun 20, 2005 | 02:51 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I used old 2X4s when I did mine. I removed the interior trim and seats then propped all carpet up off the floor by shoving boards underneath. Make sure to pull back the insulation and remove any that stuck to the sheet metal also. I had a minor lent fire over that.
As for not that much heat, maybe the welding shop I took the car to didn't know what they were doing but I definitely had some discoloration and missing paint in the spots they spot weld'd on the sheet metal floor. So, make sure you cover all bare metal spots under the car and inside with some primer and paint.
According to Spohn when I talked to him several years back he recommend'd to pull back the carpet, because he said the floor can get cherry hot.
Old Jun 20, 2005 | 06:33 PM
Car: 1988 SC Camaro
Engine: 305 TBI
thats exactly what i just did yesterday...using the boards to lift it up and back a bit...I'll find out tomorrow how i make out after they're welded on...the guy doing it said he would give me a break on the price and charge my 100 bucks to do it....sounds like a good deal to me
Old Jun 20, 2005 | 08:33 PM
Car: 1988 SC Camaro
Engine: 305 TBI
[IMG][/IMG]
Old Jun 20, 2005 | 08:34 PM
Car: 1988 SC Camaro
Engine: 305 TBI
[IMG][/IMG]
I pulled up the carpet along the outer edges and rolled it back...then i stuck some boards underneath to lift it a bit...I hope it will be ok, I'm guessing it will be just fine
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Wesly_66
Aug 26, 2015 09:55 PM
SiCkRs
Aug 8, 2015 08:12 AM
