Springs
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
Springs
Okay guys, i just finished installing drop zone lowering springs on my camaro and i was just wondering how long it takes for the springs to settle? cause right now the front end sits a little high.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
There is no set time. A combination of age and use of the car will make them settle. Don't expect any serious amount of settle. If you think they are too high double check that you indexed them correctly.
Hmmm thats weird cause they are pretty high. The end of the spring goes inbetween the two holes in the back of the a arm correct? if so then i did it right. I don't know whats wrong but its sits way to high.
I just went and looked at them and they actually got hung up on the outer part of the spring perch and wern't actually in the seat. But now they're being a PITA to install. Any tips or tricks would be appriciated.
LT1Formula
Oct 8, 2015 08:34 PM
