Strut Tower Brace for Carbureted/AC
Old Jun 22, 2005 | 08:39 AM
Pdawg502's Avatar
Car: 1984 Z28
Engine: 5.0L H.O. with Jet Chip
Transmission: 700R4 - B&M shift kit and Jet Billet Servos
Hey guys,
I have a 1984 z28 with the quadrajet and A/C. All the strut tower braces i have tried will not clear the A/C on the passenger side. All of the aftermarket products are made for the TPI models and as far as i can tell, none work with the Carb/AC combo. Does anyone know of any STB that works with my setup? I'm willing to do a little cutting/welding, just about anything short of fabricating my own.
Old Jun 22, 2005 | 08:48 AM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Edelbrock makes an STB for the TBI cars that will work on the carbed cars. Although, it doesn't fit cars with the AC compressor on the driver's side. People have modified it to work, and from what I understand it's not hard, but I couldn't tell what they did. A quick search should yield the answer.
Old Jun 22, 2005 | 11:23 AM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
The best way, in my opinion, to make a strut tower bar is to DIY.
Find a circle track shop either locally or online and buy a couple shock mounts, a pair of rod ends, and some threaded tubing.
You will then have to bolt or weld the shock mounts to the strut towers, but it's not that hard if you take your time and check your measurements.
You can easily DIY for less them $50.
Old Jun 22, 2005 | 01:18 PM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
Re: Strut Tower Brace for Carbureted/AC
Originally posted by Pdawg502
Hey guys,
edelbrock tbi brace on my 87 carbed car, comp on drvr side - minor issues with clearence - removed 1 comp support brkt and cut on another -minor issues! but works GREAT!
making your own would be the other option and woul definetly fit better too
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
tcflint
Sep 27, 2015 05:58 PM
