What is the width of the 4th gen 10 spoke?
Old Jun 23, 2005 | 12:07 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Question is what the title says. Thanks.
Old Jun 23, 2005 | 12:21 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Most Likly 8"
Old Jun 23, 2005 | 03:03 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
If it is 8" then how can they fit a 275 tire on it? I have conflicting numbers. I have seen both 17X9 and 17X9.5.
Old Jun 23, 2005 | 04:16 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
your talking about the 10spoke SS wheels? They are 17x9.5"
Old Jun 24, 2005 | 12:51 AM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
are they really? i could have sworn mine were 9. you can get a 295 on a 9.5 right? any bigger?
Old Jun 24, 2005 | 06:17 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
they should be 9", and you can put a 315 on it if you want, but I wouldn't.
I drove my friends 99 SS with 9" ZR1's with 315 Nittos DR's on them and the *** end was really squirrely when I was shifting, had 18psi in the tires.
My brother has a pair of 315 BFG G-force KD's on his 9.5" Z06 Replica wheels and they don't seem that bad since they are a street tire and run at 36psi.
Personally, I'd go with a 285/40/17 tire.
here is the 315 KD,
Old Jun 24, 2005 | 09:29 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
So which is it? One is saying 9" and another is saying 9.5". Also to measure it, is it as simple as taking a tape measure and going from lip to lip?
Old Jun 24, 2005 | 11:43 AM
Zepher's Avatar
over at SLP, they list them as 17x9,
http://www.slponline.com/view_product.asp?P=80093
Old Jun 24, 2005 | 12:32 PM
83 Crossfire TA's Avatar
bead surface to bead surface, or in most cases they have a 1/2" lip and then you can do lip to lip and subtract 1". If I remember right, all the 4th gen 17's are just slighly under 9" (actually made to some close metric size or some such BS).
sweet_87_iroc
Sep 25, 2015 10:01 PM
cam-mike
Aug 24, 2015 07:23 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
