Anyone running Centerline Wheels?
Old Jun 25, 2005 | 06:28 AM
jjarock's Avatar
Car: 1986 Z28
Engine: LG4, L98 waiting in garage
I am looking at some Centerline Wheels, Ventura style that I really like. They don't have any pics of these on a 3rd gen though. If anyone is running this setup could you post some pics?
Also, I was thinking of running 17x8 up front and 17x9.5 in the back so I can run 255's front and 275's rear. What backspacing do you have for this setup so that it will fit up decent (not stick out too far and clear everything inside)?
Thanks in advance
Old Jun 25, 2005 | 02:38 PM
KintaroOe's Avatar
Car: '91 bird '87 Z28 '86 T/A
Engine: LO3 LG4(ls1 in works) 350
Transmission: 700R in all
Axle/Gears: wimpy 10 bolts
not quite what your looking for, but they are centerlines (i think early version of telstars)
Old Jun 26, 2005 | 05:44 AM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Im running 18x9 centerline sundance lazer's with 265/35 at all 4 corners
Old Jun 28, 2005 | 08:15 AM
Raven90IROC's Avatar
Car: 1990 Camaro IROC-T
Engine: L98 Turbo (GT40)
Transmission: THO400
Axle/Gears: Forged axles, 3.23 rear
Convo-Pros
15x7 (225) and 15.8 (275)
Old Jun 28, 2005 | 11:07 AM
83 Crossfire TA's Avatar
Are those 225 60's or 70's? If they're 60's that car has to be sitting super low for the lip to be covering the top of the tire, but it doesn't look to be sitting _that_ low.
I'm assuming 275/60/15's on the back?
Either way, looks good...
Old Jun 28, 2005 | 07:30 PM
Yeah, 225/60/15s front and 275/60/15s out back.
Dropped the front a fair bit recently. Seriously helped the hard launches and doesn't look too bad
Big *** pic warning!!!
Picture picture
Old Jun 29, 2005 | 01:26 AM
Nice, that’s similar to what I’m doing at the dragstrip, but I’m using 215/65/15os on the front with 275/60/15 DR’s in the rear. I’ve been seriously considering going to 225/60/15’s in the front with 275/50/15’s in the rear.
What springs are those?
Old Jun 29, 2005 | 05:32 PM
Gary Anderson's Avatar
Raven,
Do you have rear disc brakes?
Regards,
Gary Anderson
Old Jun 29, 2005 | 06:55 PM
The springs are custom ordered from K-Mac in Sydney. Very happy with them and the ride they give.
And yes, there certainly are discs under those rims.
Old Jun 29, 2005 | 09:52 PM
Raven,
What is the backspacing on your rims and did you have to grind the calipers to get the wheels to fit? Thanks.
Gary Anderson
Old Jun 29, 2005 | 11:17 PM
Haha... F*ck no way id grind back wheels to fit breaks on. haha...
The back spacing on the rims is.... 3-3/8" from memory.
Old Jul 1, 2005 | 01:19 AM
Sorry for getting off on a tangent… those springs intended for handling, street or drag use? Any idea what the spring rates are?
Old Jul 3, 2005 | 05:11 AM
Nah not really any good for TRUE street. Definatly more intended for aiding in hard drag launches. Works a treat, but its probly a little too low for high speed street unless your on a very good road. Sorr no idea about 'poundage'
Old Jul 7, 2005 | 09:36 PM
jjarock's Avatar
Car: 1986 Z28
Thanks for all the pics!!
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
kah992
Aug 19, 2015 02:55 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
