84 WS-6 parts on a 82 base suspension
Old Jun 25, 2005 | 04:43 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
I'm adding WS-6 front and rear sway bars to my 82 trans am, however I don't have the bushings and brackets that mount the front sway bar. Can anyone tell me the correct diameter of this sway bar and where to buy these parts to mount it. How will my car do in corners with this upgrade while still using my base coil springs.
I'm also going to add a ws-6 steering box, and subframes and strut tower brace
Old Jun 28, 2005 | 01:34 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Your '82 may need a different front swaybar bracket than later models, if the bolt holes for the bracket are straight across. Assuming that's the case, you can purchase a kit with zinc-plated brackets, poly bushings, and bolts from TDS, 1982 Front Sway Bar Bushing Kit. TDS also carries a kit for the later version too.
The WS-6 front swaybar is generally 36mm in diameter.
I am sure that the larger bars will help your cornering, but I think replacing 23 year-old coil springs would really do wonders.
Old Jun 29, 2005 | 10:07 AM
Jproz1167's Avatar
Jade
I'm staying away from spring replacement since I'm certain the car doesn't need them it's a low mileage car only has about 85,000 miles. It seems to sit level and doesnt sag a bit.
Old Jul 1, 2005 | 11:35 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
'82-84 WS6 sway bar sizes are 32mm for the front and 23mm for the rear. The '84 15th anniversary T/A used 34mm and 25mm sway bars which became the standard WS6 sway bars in 1985.
Old Jul 3, 2005 | 03:07 AM
83 Crossfire TA's Avatar
My ’83 WS6 car had a 32 solid on the front but a much thinner bar in the rear, something along the lines of a 19mm.
Vintageracer
Jan 10, 2020 05:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
