Will a 15X11.5" MT ET Street fit?
Old Jul 8, 2005 | 12:30 AM
johnyIROC's Avatar
Will a set of 28X11.5-15LT MT ET Streets fit in the wheel wells of a stock thirdgen?
Here are the specs from the MT site:
Sidewall Width: 11.1
Tread Width: 8.6
I'm not worried about height... because my ride height is adjustable.... just will the width fit in the wheel wells?
My street wheels are 17X10" rims (5.75" BS) with 275/17R40 rubber and they just barely fit.
Old Jul 8, 2005 | 12:54 AM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
On a 15x8 with 4.5" BS or a 15x10 with 5.5" BS, yes they will fit.
A 11.5" ET Street is the same size as a 10.5" ET Drag.
Old Jul 9, 2005 | 07:17 PM
sixpackmtrspts's Avatar
i have an 82 camaro, i currently have a 28x10.5x15 et drag slick on it on a 15x8 rally wheel with a 5.5 backspacing. i had to cut and widen the inner wheel well in the front. basically square the inner wheel well off. i can actualy go a bit wider, i have some loaner tires coming soon that are 29x12.5.15 on a 15x10 with 5.5 bs to see how they fit.
heres the 28x10
side veiw
Old Jul 9, 2005 | 07:21 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I am running 28X13.5X15 Et Street on 15X10 with 5.5 inch backspacing. I had to pound a little on the inner wheel well and I use air bags so they don't rub on the outer fender.
Old Jul 9, 2005 | 08:25 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
27x11.5x15's dono what BS rims. I borrowed em from a buddy to test fit while I mini tub my car.
Befor I made it a vert..
http://www.cecoatings.com/images/Car...s/DSC01087.JPG
durring mini tubbing , etc..
http://www.cecoatings.com/images/Car...s/DSC01194.JPG
Old Jul 10, 2005 | 11:17 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I ran 28x10.5 ET Drags on 15x8 5.5"BS rim and had to beat the wheel wells
Street Lethal
Apr 30, 2019 12:14 PM
Reborn756
Sep 4, 2015 03:42 AM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
Eric-86sc
Aug 24, 2015 09:01 PM
z28addict8490
Aug 7, 2015 08:48 PM
