How much different is handling in decked T-top vs. Hardtop?
Car: 85 Camaro Z28
Transmission: 700-R4
I have a t-top and wanting to either take the drag or handling route. I was curious to see what you guys thought the T-top works best in. I'd like to do 1/4mile but then again a part of me is wanting to go toward autocross
Car: 1984 Camaro
Engine: 350, 4bbl
Axle/Gears: GM, 3.23 posi
T-Top cars are much more flexible and hence not as good at taking corners, but that should not stop you from doing autocross.
The best way to stiffen a T-Top car and still be 'legal' for stock class autocross in to add a 6 point roll bar. It will have the same effect as adding sub frame connectors but won't push you up in class because it is a "safety item". After you add the roll bar, your chassis will be much stiffer than a hardtop without one.
Check out www.frrax.com, it is a site dedicated to autocross and roadracing f-bodies.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
As my car got close to an 11 second pass I added a 6 point roll bar. I now have a 12 point cage since I'm just about in the 9's. I've never had a problem with the t-tops.
Thirdgen89GTA
Nov 26, 2015 11:04 PM
skinny z
Oct 5, 2015 06:23 PM
