Tire sizing and Rims
Old Aug 8, 2005 | 07:55 PM
aimless's Avatar
Car: 86 Z28
Engine: 400
Transmission: 5 spd
I was wondering if there is a difference between front and back factory 5 spoke rims(offset etc) on a 86 Z28 and the maximum size that will fit on the front and the back. I'd like to put the rears on the front 245/60/15 and install 275/60/15 on the back. Will this work? Thanks. Aimless
Old Aug 8, 2005 | 10:54 PM
83 Crossfire TA's Avatar
A bit confused… if you’ve got factory 15” rims all 4 are the same, there is no front and rear.
That being the case, 246 60 15’s _should_ fit on the front but they will rub a little (I used to autox on some G60 15’s that were supposed to be the equivalent of 245/60/15’s on all 4), probably mostly on the plastic inner fender in front and behind the tire, but it isn’t so bad that it’s going to actually harm the tire.
That combination is not going to handle great, especially on a 7” rim…
Old Aug 8, 2005 | 11:03 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Its not recommended and is borderline unsafe to run 275's on a 7" rim.
Old Aug 9, 2005 | 07:11 AM
aimless's Avatar
Car: 86 Z28
Engine: 400
Transmission: 5 spd
Thanks for the info so far, I thought I read somewhere that some factory rims for Camaros were different between the front and back. I know someone who has 275/15/60 on a 8" rim, does that extra 1" make a huge safety difference or are his tires/rims possibly unsafe also?
Old Aug 9, 2005 | 12:21 PM
Red|ine's Avatar
Car: '83 Z28
Axle/Gears: 3:73
275s on an 8" is fine, but i wouldn't myself put em on a 7, not really worth the risk, heh.
Old Aug 10, 2005 | 12:11 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Only the 16" wheels are different front and rear. The 15" are the same all around.
Yes the 1" makes a huge difference.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
toronto formula
Nov 10, 2015 06:17 AM
Djmathis123
Sep 29, 2015 01:36 AM
BlackMagic1984
Wheels and Tires
Aug 24, 2015 06:35 AM
knight72
Aug 10, 2015 09:32 PM
