Bigger RSB, what will change?
Old Aug 17, 2005 | 03:35 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Will it be dramatic or not? I have the '91 F41 and the rear I'm swapping is from an '89 IROC with a 3.42posi, so I am assuming 22mm?
Gimme yer thoughts.
Old Aug 18, 2005 | 08:35 PM
1983sc's Avatar
Car: 00' rcsb
Engine: Little boosted 5.3
Transmission: 4l80e
Just make sure you get a bigger bar up front, like 36mm, or else the rear will try and come around on corners
Old Aug 18, 2005 | 09:29 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
you have to make sure they are matched properly
get the 36 24 combo, works great
Old Aug 18, 2005 | 10:04 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Larger bar in the rear will have a tendancy to increase oversteer or make the car loose.
I have a 36mm hollow front with a 21mm rear bar, so i can apply more throttle sooner without getting as loose.
Old Aug 19, 2005 | 12:53 AM
83 Crossfire TA's Avatar
ME, I also like that combination with a stockish setup and the same size tires F and R. with bigger rear tires and a heavier axle (9” ford) I tend to like a heavier bar and stiffer springs back there…
customblackbird
Aug 15, 2021 10:16 PM
maroe624
Apr 16, 2017 08:29 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Thornburg
Aug 27, 2015 08:33 PM
Thornburg
Aug 25, 2015 01:46 AM
