T/A springs
Car: 1984 Camaro conv
Engine: 350, .040, warmed up
T/A springs
anybody know what differences there are between IROC springs and T/A springs (factory).......which would be stiffer or lower or are they the same spring ????????
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Some Z-28's and T/A's used the same springs.
There used to be a GM F-body spring rate chart posted somewhere on the net. I thought I had it saved as an image file but I can not find it on my hard drive.
AndyZ28 used the same chart in his 1LE CD-Rom.
Anyways, the BZZ fronts and the NNB rears are the stiffest production springs.
My GTA has the BZX/NNM combo.
HTH
HTH
Engine: 305TPI
If the factory tags are intact, then the three digit code and factory part number will be on the tag.
Otherwise, you would need the build sheet.
The fronts are usually the same, assuming the cars had corrisponding suspension options. The rears on the pontiac are usually one step stiffer then the comprable camaro ones.
2012sergen11
Oct 13, 2015 07:38 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Dragonsys
Sep 25, 2015 03:51 PM
