need help - rear sway bar bolts
Old Aug 22, 2005 | 07:48 PM
smiley's Avatar
hey guys. i have an '89 tta. today i had the car jacked up and noticed the rear sway bar was not connected at either end. it appears the bolts have rusted and snapped in 1/2. the driver side is missing, the passenger side is just broke. i have a manual but it does not list part number for the bolt, nuts, washers, and bushings. anyone know where i can get these parts to fix this? below are pics so you know what i'm talking about...
passenger side...
driver side....
Old Aug 22, 2005 | 08:11 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
They are called sway bar end links. I sell GM 1LE end links that I bead blast and have zinc plated (so they don't corrode so easily).
You need two per sway bar.
Lon Salgren
Top-Down Solutions
Old Aug 22, 2005 | 11:20 PM
Meatman's Avatar
Car: 1988 Formula
Engine: 355
Transmission: 6 speed
Or.........Summit sells Energy Suspension
ENS-9-8117R
Old Aug 23, 2005 | 01:33 AM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
Or you can just go to checker, they carry them, not top of the line but the do. Hey meatman where did you get your exhaust tips?
Old Aug 23, 2005 | 08:05 AM
CaysE's Avatar
Go with lonsal's 1LE parts or Spohn's Prothane parts.
Old Aug 23, 2005 | 02:12 PM
smiley's Avatar
thanks guys!!!
Old Aug 23, 2005 | 02:20 PM
smiley's Avatar
ENS-9-8117R
is that the correct size?
Old Aug 28, 2005 | 10:01 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
The ES endlinks are slightly longer than stock. 2 5/8 vs. 2 1/2.
If you do not want Lon's improved zinc-plated 1LE endlinks, the GM part number is 10221779.
Old Aug 29, 2005 | 10:11 PM
smiley's Avatar
local pep boys had them for $17... that extra 1/8" isn't going to hurt anything is it?
Old Aug 30, 2005 | 01:04 AM
83 Crossfire TA's Avatar
check the local parts stores, they will useually list a replacement and an HD replacment, which usually has poly bushings... the last time I got some HD ones they were like $6.xx
Old Aug 30, 2005 | 07:52 AM
Jade Grey's Avatar
Engine: 305TPI
My local Advance Auto stocks HD's as TRW 18203HD at $5.68 each.
Old Aug 31, 2005 | 01:33 AM
yea, same ones that I was saying were $6 but at the time I bought them I think they were still Trak Auto...
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
z28addict8490
Aug 7, 2015 08:48 PM
