Need A Diagnosis Doctors
Old Aug 28, 2005 | 11:04 AM
irocyourpants's Avatar
Car: iroc
alrite the iroc (90' 5.7l if it makes any difference) has been making alot of fun noises lately and i was just looking to get a few opinions from some people who know what there talking about ive recently had the center link and inner tie rods replaced along with a full alignment
i regularly grease the zerks on every oil change
now heres the problem at parking lot speeds i notice a lot of groanin and low pitch squeaking along with som vibration of the steering wheel and floorboard when im turning the steering has very little play and it is perfectly aligned so my guess its some worn bushings or bearings but i dunno
any opinions? thanks for the help
Old Aug 28, 2005 | 11:15 AM
DeanE's Avatar
Just glancing at your post, I am not going to read it. At least try to punctuate next time ....Please.
I am not the best either, but at least I make an effort so others can read it.
Old Aug 28, 2005 | 01:23 PM
Car: iroc
ummm ok thanks for ur opinion but i dont really need a smart *** attitude like urself in here u dont like it dont leave a response
Old Aug 28, 2005 | 01:48 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
well, i'd try to punctuate a bit better, makes it easier to read and understand, plus dean is pretty much the guru of suspension on here.
i'd grease the wheels bearings, and check your balljoints.
i replaced everything in my front end suspension, and all the groans squeeks and such are gone.
thats centerlink, idler arm, inner and outer tie rods, and balljoints
also look into getting a wonderbar, helps alot
Old Aug 28, 2005 | 01:49 PM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
I would check your power steering belt for tension and cracks, and then the fluid.
Lots of cars with power often groan at full lock, and it doesnt always mean a real problem. Its worse with steering boxes than rack and pinion usually though.
Check the belts not frayed, your steering oil is clean, and check the mountings\frame where the steering gear fits and make sure nothings loose cracked or broken.
Old Aug 28, 2005 | 01:59 PM
Jason89RS's Avatar
How about sub frame connectors, do you have them? If not then they could help with some of the groaning and creaking.
Old Aug 28, 2005 | 02:09 PM
Car: iroc
thanks for the tips guys there most appreciated
89GTAOz
May 16, 2020 09:31 AM
BumpaD82
Feb 26, 2016 02:57 PM
Magman
Sep 12, 2015 11:55 PM
whtltng89
Sep 8, 2015 07:06 PM
brettd
Feb 4, 2002 03:42 PM
