36mm urathane bushings part #?
Old Sep 3, 2005 | 04:46 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
Hey there. So I took a caliper and measured both my IROCs sway bars.. they are the same. Looks like 30mm front and 19.5 rear. Little bit of flaking paint and surface rust may have boosted those numbers a bit, but thats pretty acurate.
So I decided to invest in a set of 36/24mm bars. I went out to the local auto supply store (Lordco) and ordered up some poly urathane bushings and endlinks. They deal with Energy Suspension.
They do not list 36mm bushings for Chevy or Pontiac.. only upto 34mm? Also they list the 34mm w and w/o thrust washers. I have both sets sitting in front of me now. Will these work for the 36mm bars? Also do I need the thrust washers, or not?
No problem getting the front end links. No problem getting the 24mm rear bushings.
Anything else I should replace while I'm there?
Thanks.
Old Sep 3, 2005 | 04:49 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Board sponsors, Spohn and TDS, both carry greaseable 36mm bushings. TDS also provides 1LE endlinks, which are quite nice and highly recommended.
JamesC
Old Sep 3, 2005 | 05:13 PM
Brisk's Avatar
anything I can get 'quickly' that would be avaliable in Canada?
Old Sep 3, 2005 | 05:24 PM
JamesC's Avatar
I can't say positively, of course, but I sincerely doubt it.
JamesC
That said, I can dig up the GM 1LE part number if you'd like--this bushing is a higher durometer rubber.
Old Sep 3, 2005 | 08:01 PM
Brisk's Avatar
Ok so I got ahold of a 'good' caliper.. I was using a junky dollar store one.
I measured both cars, both are the same.
Fronts are 34mm
Rears are showing like 22.5 mm.. so I'm assuming 22.
Fronts are hollow. One car has the 'hollow holes' facing down to the ground, one car has the holes facing up towards the engine.
Which way is proper?? I know one car was in an accident years ago.. and that one has the holes up.. I'm assuming that is the one that is incorrect?
Also.. now that I know I have 34/22mm, is it really worth upgrading to 36/24??
Advice needed, thanks!
Old Sep 3, 2005 | 08:06 PM
Brisk's Avatar
oh and thanks JamesC.. I've already got the poly end links in front of me.. they're probably better (?) then the 1LE ones in the long run..?
Old Sep 4, 2005 | 05:57 AM
JamesC's Avatar
The 1LE's are poly too. I prefer them because their curved head seems to fit the sway bar hole better, but the ES stuff is fine--I'm running their motor mounts, tranny, torque arm mount, secordardy cross-member mounts, bump stops, and rear sway bar bushings.
JamesC
Old Sep 5, 2005 | 09:12 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
FYI, those white "1LE" sway bar bushings pictured can be had on almost any rear ( and possibly front) 4th gen swaybar. I got 2 4th gen rears a whle back and both of them had the "1LE" sway bar end link bushings.
Ed
Old Sep 5, 2005 | 03:46 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Aren't they actually hard nylon?
Old Sep 5, 2005 | 03:52 PM
JamesC's Avatar
Humm, well, I guess I couldn't really say. At any rate, they seem effective.
JamesC
Old Sep 5, 2005 | 05:11 PM
ss86's Avatar
Car: 78 Malibu
Engine: 357
TDS at the top of the page sells them and their description said Nylon. I was about to buy them if they are hard nylon. Does anybody know for sure?
Old Sep 5, 2005 | 05:33 PM
JamesC's Avatar
They're hard.
JamesC
Old Jan 8, 2008 | 05:36 PM
scojack_2001's Avatar
Car: Grand National
Engine: 3.8 Turbo
Transmission: 200-4R
Axle/Gears: 3.42 G80
Re: 36mm urathane bushings part #?
Sorry to bring back an old thread. I am considering upgrading to a 1LE swaybar on my GN, and was wondering if I had to use the F-Body bushings and endlinks. So I guess all the 34mm and 36mm are "1LE"s????
Any got a Energy Suspension part number handy for the bushings and links?
Old Jan 8, 2008 | 05:56 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
I dont have the number handy, but I did a little research and found that a 2001 Silverado 2wd uses 36mm front sway bar bushings that will work with our cars. I bought them from summit (they had to order them directly from energy suspension) and installed them, and they fit perfectly.
Old Jan 8, 2008 | 06:07 PM
JamesC's Avatar
IIRC, both Spohn and TDS, both board sponsors, carry the 36 mm bushings. TDS carries the 1LE end links. I prefer the ES links as they seem to fit better.
JamesC
Old Jan 8, 2008 | 06:52 PM
Car: Grand National
Engine: 3.8 Turbo
JamesC
Thanks guys. Im just trying to improve the handling of my GN. The 16x8 GTAs helped, but Im gonna redo the whole front suspension. I found a 36mm bar for sale on this board, hopefully I can snag it up...
Im thinking BMR control arms, LS-1 car brakes, and a maybe IROC springs; depending on thier rate. Also a SC&C frame brace and a new steering box. Already have KYB shocks for the front. Also gonna do the steering as well.
Any tips appreciated.
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
