a-arm question
Old Sep 5, 2005 | 07:48 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
a-arm question
i am rounding up parts for a front end rebuild on my 85 z-28 and found that one of the ball joints has been welded to the a-arm. is an a-arm off of a 85 v-6 the same as one off of a 85 z-28?
do the moog parts have poly bushings? i am going with moog or psc.
psc(or moog) rebuild kit +centerlink & sleeves
struts and shocks
hotchkis springs 1" drop
tubular rear control arms from spohn
new hardware for front and rear control arms from spohn
poly spring isolaters
strut mounts
adaptors for strut mounts from spohn
did i miss anything? im not building a drag racer. i just want to be able to drive without sawing back and forth constantly.
Old Sep 5, 2005 | 07:59 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Yes, the V6 cars had the same a-arms. Moog bushings aren't poly, but I would use them in a heartbeat.
How about...
Tie-rod ends
Idler Arm
Sway-bar bushings and links
Bumpstops
Adjustable Panhard Rod (for lowered rear-end centering)
Sounds good so far!!
Old Sep 5, 2005 | 08:06 PM
hoogabooga's Avatar
Engine: 427 454
Transmission: TH400
everything comes in the psc kit except centerlink and sleeves.
do i have to have the adj. pan rod?
Old Sep 5, 2005 | 08:20 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
It will help center your rear-end once the car is lowered. Mine was out about 1/4" after lowering.
Old Sep 5, 2005 | 08:25 PM
hoogabooga's Avatar
Engine: 427 454
Transmission: TH400
thanks for the help. wife is already mad because i have spent over $700 on car parts since friday, so whats another $125.
Old Sep 6, 2005 | 12:28 PM
CaysE's Avatar
Women will test your resolve to no end. Just stick with it and give her some extra attention later on.
Do you have a link to the Moog rebuild kit you're looking at? The one Spohn sells does come with the Moog centerlink and Spohn's heavy-duty sleeves.
As for recommendations, I would go with GM spring isolators. Poly isolators are just a waste of money and add unnecessary noise to the car. The A-arms will require bumpstops (go with Moog, this part shouldn't be poly either), bushings (poly from ES or Prothane), and ball joints (Moog). Rear control arms will require bushings (poly from ES or Prothane) and relocation brackets (Spohn).
Depending on what are in those two rebuild kits, everything else looks great.
Old Sep 6, 2005 | 02:56 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Take a look at the a-arms before you buy. Typically, the end link bolt hole ovals out.
JamesC
sweet_87_iroc
Sep 25, 2015 10:01 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
