Formula wheels.
Car: 1991 pontiac Firebird
Engine: 305 tbi, Lo3 (for now)
Transmission: auto
Axle/Gears: stock (for now)
Formula wheels.
What are the dimensions on 3rd gen formula wheel. I have the standard 15 inch firebird wheels, but was thinking about going with the formula wheels. Im pretty sure they are wider, because I seem to remember seeing a formula with a 255 tire. But are they 15s or 16s. And are they wider than my factory 15 inchers. I might be building a sleeper, and want as much tire on the ground as possible. How wide of a tire can go on the formula wheels, safely. Thanks, in advance.
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
The Formula rims are 16x8s. They have different offsets for the fronts and rears, so you will want to try and find a complete set. You'd have to check with the tire manufacturer, but most recommend you don't go over a 255 on an 8" wide rim.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The factory tires are 245/50R16's The 255's work fine but I did not like how they stuck out slightly wider. Although it was subtle.
John
John
Linson
Oct 1, 2015 09:50 PM
